Description
I’ve identified what seems to be a bug in the OAuth2 PKCE implementation in the N8N credential system, where the client_secret
is not sent in the final token exchange, even though it’s configured and required by the target API (Mercado Livre).
This leads to authentication failure during the last step of the PKCE flow.
Context
- N8N version:
1.86.0
- OAuth Grant Type selected:
PKCE
- Authentication method:
Body
- Authorization URL:
https://auth.mercadolivre.com.br/authorization
- Access Token URL:
https://api.mercadolibre.com/oauth/token
- Redirect URI:
https://<my-domain>/rest/oauth2-credential/callback
client_id
,client_secret
, and other fields were filled in as expected
Expected behavior
After the user is redirected back with the code
parameter, N8N should send a POST request to the token endpoint with the following body (application/x-www-form-urlencoded):
text
CopyEdit
grant_type=authorization_code
client_id=***
client_secret=***
code=***
redirect_uri=***
code_verifier=***
But…
Actual behavior
- N8N generates the
code_verifier
andcode_challenge
correctly - It successfully builds the authorization URL and redirects the user to login
- Upon receiving the callback, it fails with this response:
json
CopyEdit
"error": "invalid_request",
"message": "the following parameters are required: grant_type, client_id, client_secret, code, redirect_uri. Missing parameters: client_id, client_secret"
After inspecting the developer console and network tab, it was confirmed that:
code_verifier
is sentclient_id
andclient_secret
are not sent at all- Even though they are configured,
client_secret
is replaced by__n8n_BLANK_VALUE_xxx
in the internal callback URL
Manual test (confirmation)
To isolate the issue, I manually performed the PKCE flow using the exact same:
code_verifier
code_challenge
- Authorization URL
- Redirect URI
- Token URL
Using cURL and Postman/Apidog, when all fields are sent manually — including client_secret
— authentication succeeds perfectly.
This confirms that the issue is on the N8N side and not with the target API.
Additional Notes
The API in question requires client_secret
even in PKCE mode — which is valid per OAuth2 RFC 6749 §4.1.3.
How to reproduce
- Create an OAuth2 credential in N8N using
PKCE
grant type - Fill in all required fields, including
client_id
andclient_secret
- Use a service that requires
client_secret
even in PKCE mode (e.g. Mercado Livre) - Try to authenticate
- You’ll see an error message:
Possible workaround
Manually performing the authorization flow and using Header Auth
in N8N with the token obtained outside of N8N is the only workaround for now.
Request
Please consider updating the PKCE implementation to allow inclusion of client_secret
in the final token request, for APIs that require it. Alternatively, allow manual override of token exchange payload when using PKCE.
Let me know if you need reproducible credentials with a public API.
