Job Description / Post Body:
Hi!
I’m looking for an experienced n8n freelancer (or expert in Make.com/Zapier if n8n isn’t your specialty) to build a reliable two-way task synchronization between Craft.do and Todoist. I don’t have time nor the expertise to set this up myself, so I need someone who can handle the full build, testing, and handover quickly.
Key Requirements:
When a new task is created in Craft.do → create it in Todoist with a back-link to the Craft task (using craft://open? scheme or share link if possible).
When a task is completed in Todoist → mark it as done in Craft.do.
When a task is completed in Craft.do → mark it as done/completed in Todoist.
Handle basic matching to avoid duplicates (e.g., store Todoist task ID in a Craft sub-block/note, and Craft block ID in Todoist description).
Use polling/scheduling for Craft (since no webhooks), e.g., every 10–30 minutes.
Use Todoist triggers/webhooks where possible for faster updates.
Deploy on n8n Cloud (I’ll provide account access or set up a shared workflow).
Include error handling, logging, and easy way for me to pause/monitor.
Provided by me:
Craft.do API base
Craft API token (Bearer auth)
Craft document ID and space ID
Todoist API Key
Any other details needed (e.g., preferred project in Todoist - Inbox)
Nice-to-haves (if time allows):
Handle subtasks if present.
Option to reopen/uncomplete if status changes back (though Todoist limits this).
Basic dashboard/notifications if issues arise.
Budget & Timeline:
Fixed-price preferred: $150–$350 (depending on complexity; happy to discuss after quick scope chat).
Or hourly if you prefer ($25–$60/hr range based on typical rates).
Timeline: Ideally completed in 3–7 days (including testing and 1–2 rounds of revisions/handover).
Delivery: Share the full workflow JSON/export so I can import it, plus short video/explanation of how it works and any ongoing costs (e.g., n8n Cloud Starter ~$20–24/mo).
I’m a non-technical user, so clear communication and simple handover are important. Please reply with:
Your experience with n8n (or similar tools) and API syncs (e.g., links to past similar projects if possible).
Estimated price and timeline for this scope.
Any questions/clarifications needed upfront.
Looking forward to your proposals – thanks!
Posted by Heath – happy to hop on a quick call if needed.
