Building a knowledge-base chatbot for a client—what’s still stopping you from handing it over?
If you’re delivering a chatbot that answers from client documents, what question about its reliability is still unresolved?
For example:
- The demo works, but the client’s questions expose missing information.
- A document update leaves the bot answering from an older policy.
- You changed the search setup, but can’t tell which questions improved or regressed.
- The answer looks correct, but its citation doesn’t support the claim.
I work on independent retrieval evaluations. In a recent small application check, the developer confirmed gaps in citation traceability and retrieval logging and implemented changes. Independent verification of those changes is still pending.
If you have a specific delivery problem, share what changed, one sanitized example, and what you need to decide before handoff. I can help identify what the available evidence supports and what needs checking next.
My main scope is comparing retrieval results and evaluation consistency. Broader reviews would need a separately agreed scope.
What is the unresolved issue in your current client project?
In my client work, I stopped treating handover as a launch date and started treating it as a test I could repeat. If I can’t re-run the same questions after a change and show what got better or worse, I’m not ready to hand it over, however good the demo looks.
The thing that changed it for me was a small frozen test set. I take 25 to 40 real questions from the client, not ones I invented, and for each one I write down the expected answer and the exact document and version it should come from. That set gets run before and after every prompt, chunking, or retrieval change. Without it, you’re just guessing whether a tweak helped. With it, a regression is a number, not a feeling.
For stale documents, the fix is boring but it works: every chunk carries its source and version, and an update re-indexes and removes the old version rather than adding a second copy beside it. I then re-run the questions tied to that policy specifically, because a general smoke test will miss a quiet change in wording.
Citations are where I get strictest. If the retrieved chunks don’t actually support the sentence, the bot should not dress it up as a fact. I have it say what it found, and where it falls short, instead of filling the gap. Those “not covered” answers are valuable: I log them weekly, and that log becomes the client’s content-gap list. A chatbot that admits a gap is far easier to trust than one that sounds confident and is wrong.
At handover I leave three things: the test set and its latest results, the known gaps and who owns each document, and a simple rollback note for the last working prompt and retrieval settings. That is what turns a demo into something a client can actually run.
