Building a Multi-Tool AI Agent Workflow in n8n
I recently built a powerful AI-driven automation workflow in n8n, and it turned out to be a great hands-on experience designing a system that connects multiple services into one intelligent pipeline.
What This Workflow Does
At its core, this setup centers around a single AI Agent that acts as the brain of the entire operation. Instead of building separate automations for every task, I funneled everything through one intelligent agent that can understand context, make decisions, and trigger the right action on its own.
The workflow accepts inputs from several entry points:
  • Chat messages: a “When chat message received” trigger for direct conversational requests
  • Webhooks: including a dedicated “Retrieve Deep Research” webhook and a “Respond to Webhook” node to send results back
  • Session handling: SetSessionID, SetResearchID, and ToolCall nodes manage state and keep each request properly tracked
From there, everything routes into the AI Agent for processing.
The Tools Behind the Agent
What makes the agent genuinely useful is the set of tools wired into it:
  • OpenAI Model: the language model powering the reasoning
  • Memory: so the agent retains context across the conversation
  • Calculator: for any on-the-fly computation
  • Google Sheets: reading and writing data to a connected sheet
  • Gmail: sending messages and creating drafts automatically
  • Task management: Get Active Tasks, Create Task, and Update Task nodes for full task handling
  • Deep Research: Retrieve and Conduct Deep Research nodes for pulling richer information
  • Shopping List management: Get, Add to, and Update Shopping List nodes
  • CreateHTML & Edit Fields: for formatting and shaping output
I also scaffolded in Microsoft Teams and Home Assistant nodes (currently deactivated) so the system can expand into team messaging and smart-home control down the line.
What I Learned
The most interesting part was structuring the logic so the agent could interpret a request, decide which tool to reach for, and execute, whether that meant creating a task, drafting an email, running research, or updating a sheet, all without manual intervention.
This project deepened my skills in:
  • Designing AI agents that orchestrate multiple tools
  • Workflow automation and state management
  • API integrations across Google, Gmail, and more
  • Building scalable no-code / low-code systems
It’s exciting to see how automation can turn a tangle of complex steps into one simple, efficient process. :rocket:
The session handling via SetSessionID/SetResearchID is a solid architectural choice - keeping those as dedicated Set nodes before the Agent makes it easy to swap the ID logic without touching the agent itself. One pattern worth considering as you scale to more tools: grouping related tools (like the task management cluster or the research cluster) into separate sub-workflows called via the “Execute Workflow” tool lets you version and test each group independently without redeploying the whole agent.
That’s a great point.
I agree, keeping the session and research ID logic outside the agent makes the workflow much easier to maintain. The agent can stay focused on decision-making, while the ID/session layer can be changed independently when the workflow grows.
I also like the idea of splitting tool groups into separate sub-workflows. For example, task management, research, Gmail, and Sheets actions could each live in their own workflow and be called through Execute Workflow when needed.
That would make the overall system cleaner, easier to test, and safer to update without touching the main agent every time. Definitely a good pattern for scaling this beyond a single workflow.
Following the sub-workflow point above — one thing I’d add from building agent-based automations for freelance clients: the failure mode worth watching for as this tool list grows isn’t just maintainability, it’s decision quality. An agent choosing between 8-9 tools (Sheets, Gmail, Tasks, Shopping List, Deep Research, Calculator…) tends to pick the wrong one more often than an agent choosing between 2-3, even with a good system prompt — more options per turn seems to correlate with more reasoning errors, not just more maintenance overhead.
Splitting into sub-workflows (like @nguyenthieutoan suggested) actually helps with this too, in a way that’s separate from the versioning benefit: if each sub-workflow exposes itself to the main agent as a single tool (“handle_task_management”, “handle_research”) rather than exposing 3-4 tools per domain, you cut the top-level agent’s real decision surface down to maybe 4-5 choices instead of 9+, even though the total tool count in the system hasn’t changed. The complexity just moves down a level, to sub-agents that only have to choose among 2-3 tools each.
Curious if you’ve noticed the agent misfiring more as you added Home Assistant/Teams into the mix, even deactivated?
This is a great example of how AI agents can simplify complex automation workflows. I especially like how you’ve connected Gmail, Google Sheets, task management, and deep research through a single AI Agent. Managing session state and tool selection is also important for building reliable workflows. For anyone interested in exploring more automation solutions, this AI workflow tools directory is worth checking out. It covers different tools for connecting apps and automating repetitive tasks. Overall, a very interesting n8n project!
This is a really interesting implementation of n8n. I like how you’ve used a single AI Agent to coordinate multiple services instead of creating separate automations for every task.
The combination of Gmail, Google Sheets, task management, and deep research makes this workflow useful for handling different types of requests through one system. The session and research ID handling is also important because it helps keep requests organized and maintain context.
A few things I would consider as you expand this setup:
  • Error handling: Add clear error paths so a failed API request or unavailable service doesn’t interrupt the entire workflow.
  • Human approval: Keep confirmation steps before sensitive actions, such as sending emails or modifying important records.
  • Memory management: Define how long conversation context should be retained and how separate users or sessions are handled.
  • Workflow monitoring: Track failed executions and API responses so problems can be identified quickly.
  • Scalability: Keep individual tasks modular so new integrations can be added without making the main workflow difficult to maintain.
I also think combining an AI Agent with a dedicated task management platform can make complex processes easier to manage. This guide to workflow management software covers platforms that help organize tasks, automate processes, manage approvals, and improve team coordination.
The planned Microsoft Teams and Home Assistant integrations could open up some interesting possibilities too. Overall, this is a good example of how n8n can connect multiple services into one flexible automation system.
I’m curious how you’re planning to handle simultaneous requests and prevent two agent executions from updating the same task or record at the same time.
