Building a string from a sheet
Hello! I am trying to build a string sequentially as I iterate through a Google Sheet. I have seen this question asked a couple times, but those answers didn’t fit my use case.
From a high level, I am using a formatted spreadsheet to build a Wordpress form export file. This lets me generate forms from a spreadsheet and is super useful. I built it in Make.com but am trying to move over to n8n.
To build the form, I have to make a json structure with a header, body fields and a footer. So I need to store a value and slowly build on that value for each row in the spreadsheet.
Here is a loom video for context to the problem:
  • n8n version: 1.78.1
  • Database SQLite:
  • n8n EXECUTIONS_PROCESS setting own, main:
  • Running n8n via n8n cloud:
  • Operating system: Windows
Hey Nick, if I understand correctly it only outputs the first result from the row, or the last?
Sorry, the workflow isn’t complete. This needs to loop through the entire spreadsheet and collect data from all rows. At the moment I am only processing the first row but once I know how to build a string I will complete the loop
