Built a No-Code AI Compliance Agent with n8n + Hidemium
In fast-moving online environments, keeping your operations compliant with platform policies (e.g., Google, Meta, Amazon) is a daily challenge — especially when scaling accounts, content, or marketing campaigns.
That’s why I built an AI-powered compliance agent using n8n (no-code automation) and Hidemium (anti-detect browser), to automate detection and adaptation workflows.
Here’s what it does:
:white_check_mark: Use Case: Compliance & Policy Monitoring Agent
:hammer_and_wrench: Stack Used:
  • n8n – Automation engine
  • Hidemium – Anti-detect browser with prompt scripting AI
  • OpenAI / Claude / LLM API
  • Google Search API + Screenshots
  • Slack or Telegram for notifications
:brain: What It Does:
  1. Crawls target platforms (via Hidemium browser profiles)
  • Each profile mimics a real device with unique fingerprint
  • Loads pages under different IPs, geo-locations
  1. Screenshots or extracts content from platform policy pages, flagged content, or marketplace listings
  2. LLM analyzes text/images for:
  • Policy violations
  • Sensitive wording
  • Shadowbanned terms
  • TOS updates
  1. n8n routes alerts to you via Slack, Email, or Telegram with action suggestions
:bulb: Why Hidemium?
Unlike other headless browsers or Puppeteer setups, Hidemium:
  • Uses real browser UI (avoids bot detection)
  • Each profile runs isolated (fingerprint-safe)
  • Includes Prompt Script AI: just describe your workflow, and it builds the form-filling or scraping logic for you — no coding.
:arrows_counterclockwise: Result:
In our test across 10 different Google accounts and several eCommerce platforms:
  • Agent detected 3 TOS updates within 24h
  • Flagged 2 product listings that would have been delisted
  • Suggested adjustments to ad copy before suspension happened
:test_tube: Want to Try It?
Hidemium offers a free trial with 5 profiles
n8n is open source
You can deploy this agent in under 1 hour without writing code.
Happy to share the base workflow or answer questions!
This sounds really powerful!
Curious — how reliable is Hidemium when scraping from platforms like Meta or Amazon, especially when rendering JS-heavy pages? Have you run into rate-limiting or content-block issues yet?
Super impressive setup!
Would you be open to sharing the Hidemium script structure or a sample JSON from n8n?
I’d love to repurpose this for ad copy compliance checking before launch, especially on Google Ads.
