Built a RAG system in n8n + Supabase.......some things that actually tripped me up
I built an internal knowledge copilot: ask a question in Telegram, get a cited answer from your company docs. If it doesn’t know, it says so.
Stack**:** n8n on Railway, Supabase pgvector, Gemini embeddings (768d), Groq LLaMA 3.3 70B, Google Drive as the source.
Three workflows:
  • Ingestion — chunks PDFs, embeds, upserts to Supabase. Skips unchanged files by diffing Drive modifiedTime vs stored timestamp.
  • Query — hybrid retrieval (pgvector + full-text, fused with RRF) → LLM re-rank → confidence gate → cited answer in Telegram
  • Eval — weekly run against a fixed Q&A set, scores groundedness, sends a digest of top unanswered questions
Things that actually cost me time:
Gemini cosine similarity for relevant chunks lands around 0.51–0.65, not 0.8+. I had my threshold at 0.72 and it was refusing good answers the whole time.
After any connection surgery in n8n, always re-validate for “Node not reachable” — removing one connection can silently drop both if two ports share the same target.
Anyone else using pgvector with n8n? Curious how your similarity scores look with other embedding models.
The embedding similarity threshold issue is a real gotcha - Gemini’s text-embedding-004 returns compressed scores compared to OpenAI’s embeddings, so calibrating to 0.5-0.6 is the right move. One thing I’d add to your Eval workflow: track which questions consistently fall below threshold vs which return wrong answers - they need different fixes (retrieval tuning vs prompt/re-ranking tuning). The weekly digest is solid, but a per-failure-type breakdown makes it much faster to target improvements.
