Built a reading notes generator for book clubs and heavy readers
Most people who read nonfiction don’t retain much of it. You finish a chapter, could roughly describe what it was about, but ask about a specific argument or quote two weeks later and it’s gone. The ideas that made you nod while reading disappear because nothing forced you to process them.
Taking proper notes takes almost as long as reading the chapter itself. So most people don’t.
Built a workflow that generates structured reading notes automatically when a chapter PDF lands in Drive — themes, key concepts with definitions, main arguments, notable quotes with page numbers, discussion questions, action items, and an AI insight summary. Two parallel passes, posted to Slack before you’ve closed the PDF.
What it does
Chapter PDF dropped in Drive → two parallel passes (structured extraction + AI insights) → compiles notes → logs to reading log → posts full summary to Slack
About 15-20 seconds per chapter.
Two passes on the same chapter
Pass 1 — Structured extraction:
  • Book title, author, chapter number and title, page range
  • Main themes (as array)
  • Key concepts — each with definition
  • Main arguments — numbered list
  • Statistics and data cited
  • Notable quotes — text with page number
  • Vocabulary terms with definitions
  • Chapter summary
  • Main takeaway
  • Discussion questions
  • Action items
Pass 2 — AI insights:
  • 3-4 sentence chapter summary
  • Single most important insight from the chapter
  • How it connects to broader themes
  • One practical action the reader could take
Both run in parallel, merge before Slack notification.
What lands in Slack
📚 Chapter Summary
Book: Thinking, Fast and Slow
Author: Daniel Kahneman
Chapter: 12 - The Science of Availability
📋 Summary Stats:
• Themes: cognitive bias, memory, risk perception, heuristics
• Key Concepts: 4
• Arguments: 6
• Quotes: 3
• Action Items: 2
💡 Main Takeaway:
We judge the frequency of events by how easily examples
come to mind — not by actual data — which systematically
distorts our perception of risk and likelihood.
🧠 AI Insights:
This chapter demonstrates how the availability heuristic
creates predictable errors in judgment across domains from
insurance to personal safety decisions. The most important
insight is that emotional salience overrides statistical
reasoning even when we're aware of the bias...
One practical application: before making any risk assessment,
deliberately ask "what data do I actually have vs what examples
am I remembering?"
❓ Discussion Questions:
Q1: Can you identify a recent decision where availability bias
may have influenced your thinking?
Q2: How do news cycles exploit the availability heuristic?
Q3: What systems could reduce availability bias in organizational
decisions?
🔗 View Chapter
What lands in Google Sheets
Each row: Book, Author, Chapter #, Chapter Title, Pages, Main Themes, Key Concepts (count), Arguments (count), Quotes Noted (count), Action Items (count), Main Takeaway, Read Date
Your complete reading history in one sheet. Every book you’ve read, every chapter logged, searchable by theme or concept.
You’ll need:
  • Google Drive (folder for chapter PDFs)
  • Google Sheets (free)
  • n8n instance (self-hosted — uses PDF Vector community node)
  • PDF Vector account (~6-8 credits per chapter for two passes)
  • Slack (for reading notes sharing)
About 10 minutes to configure. Works well for book clubs — point Slack to a shared channel so everyone gets the notes together.
Download
Workflow JSON:
ebook-chapter-summarizer.json
Full workflow collection:
khanhduyvt0101/workflows
Setup Guide
Step 1: Get your PDF Vector API key
Sign up at pdfvector.com — free plan works for testing.
Step 2: Create Drive folder and Sheet
Folder: “Book Chapters” — copy folder ID.
Sheet headers:
Book | Author | Chapter # | Chapter Title | Pages | Main Themes | Key Concepts | Arguments | Quotes Noted | Action Items | Main Takeaway | Read Date
Step 3: Import and configure
Download JSON → n8n → Import from File.
New Chapter (Drive Trigger):
  • Connect Google Drive (OAuth2), paste folder ID
PDF Vector Extract + PDF Vector Insights:
  • Both run in parallel from Download Chapter
  • Add PDF Vector credential to both nodes
Log to Reading Notes:
  • Connect Google Sheets, paste Sheet ID
Send to Slack:
  • Connect Slack, select your channel (personal or book club)
Accuracy
Tested on nonfiction chapters from business books, academic texts, and self-help books.
  • Book title, author, chapter identification: ~97%
  • Main themes: ~93%
  • Key concepts with definitions: ~90% — reliable when concepts are explicitly defined in the text
  • Notable quotes with page numbers: ~88% — page numbers only when the PDF preserves them
  • Discussion questions quality: ~91% — generates thoughtful questions for most nonfiction
  • Action items: ~85% — depends on how prescriptive the chapter is
Works best on nonfiction. Fiction chapters extract themes and quotes but discussion questions are less useful.
Cost
~6-8 credits per chapter for two passes. Free tier covers ~12-15 chapters per month — one book roughly.
Customizing it
Book club mode:
Route Slack to a shared group channel. Everyone in the club gets the notes and discussion questions automatically after each meeting’s chapter is uploaded.
Spaced repetition:
Add a scheduled workflow that reads your Sheets log weekly and re-posts the main takeaway from a chapter you read 7 days ago — forces review without extra effort.
Connect to Notion:
Replace or supplement Sheets with a Notion database — create a book page per title and add chapter notes as subpages for a clean reading library.
Limitations
  • Requires self-hosted n8n (PDF Vector is a community node)
  • Page numbers in quotes only work on PDFs that preserve page metadata
  • Two-pass approach uses more credits than single-pass workflows
  • Fiction works less well than nonfiction for this use case
PDF Vector n8n integration
Questions? Drop a comment.
nice setup, the two-pass approach makes sense for keeping latency down. curious whether this works on scanned PDFs (image-only, no text layer) — wondering if PDF Vector handles OCR internally or if it just doesnt work on those and needs a clean digital source.
