Built a Roofing Lead Generation & AI Voice Outreach System with n8n
I’ve been building an automation system for roofing businesses that connects lead discovery, qualification, research, AI personalization, and outbound calling into one workflow.
The goal was to reduce the amount of manual work between finding a potential roofing company and determining what happened with the lead.
The workflow
The system currently follows this general pipeline:
Google Maps / Apify → Lead Filtering → Deduplication → Google Sheets → Competitor Research → AI Personalization → Vapi Voice Call → Outcome Classification → Lead Update
The lead scraper looks for roofing businesses in selected cities, filters for businesses without a website, checks for phone availability, removes duplicates against the existing lead sheet, and appends new leads.
The second workflow then handles the outreach side. It checks lead eligibility and local calling hours, researches a relevant competitor, generates a tailored opener with AI, starts an outbound Vapi call, checks the call status, classifies the outcome, and updates the lead record.
I also added spacing between completed calls and logic for follow-ups and different call outcomes.
Stack
  • n8n
  • Apify
  • Google Maps data
  • Google Sheets
  • SerpAPI
  • OpenAI
  • Vapi
What I found interesting
The interesting part wasn’t any single API connection. It was getting the individual pieces to behave like one operational system.
For example:
  • Don’t call a lead outside its allowed local hours.
  • Don’t keep adding duplicate businesses to the lead sheet.
  • Research the prospect before generating the opener.
  • Don’t treat every call outcome the same.
  • Keep track of attempts, follow-ups, booked meetings and do-not-call outcomes.
I’ve documented the architecture and the project here:
Akin Stack — Roofing Lead Automation Case Study:
I’m sharing this mainly to get feedback from other n8n builders.
If you’ve built similar lead-generation or AI voice workflows with n8n, I’d be interested in how you handle retries, call failures, qualification logic, and human handoff.
This is a solid workflow, especially the focus on deduplication, local calling hours, and tracking different call outcomes. One thing I’d prioritize is adding retry logic with limits and error handling for failed API calls, along with a human handoff when a prospect shows genuine interest. Also, make sure the outbound calling process follows applicable consent and do-not-call regulations. How are you currently handling cases where Vapi calls fail or the AI can’t confidently classify the outcome?
