Subject: Built-in Pagination fails to increment $pageCount - proven with webhook.site
Hello N8N Team,
I’m facing a critical issue with the built-in pagination feature on the HTTP Request node.
Goal: Paginate a standard REST API that uses a page query parameter.
Problem: The node fails with the error “The returned response was identical 5x, so requests got stopped”.
Diagnostics Done:
cURL Test: The API and my credentials work perfectly. A
curlrequest with&page=2correctly returns the second page of data. -
Webhook.site Test: This is the definitive proof. I configured the HTTP Request node to send its output to webhook.site.
- Result: N8N sends multiple requests as expected, but the
pagequery parameter is stuck at1for every single request. The$pageCountvariable is not incrementing.
Conclusion:
This proves the issue is not with the target API, but with the N8N environment failing to update the $pageCount variable during pagination.
Configuration:
- Pagination Mode:
Update a Parameter in Each Request - Parameter Name:
page - Parameter Value:
{{ $pageCount + 1 }} - Pagination Complete When:
Response Is Empty
I have also already tried building a manual loop with SplitInBatches and the $resumeIndex variable, and it also failed in a similar way, suggesting the issue is with N8N’s internal loop counters in my environment.
Can you please help? I can provide screenshots of the webhook results.
