I built a workflow that imports a whole product catalog from a CSV file into Paddle or Stripe, so you don’t have to create each product and price by hand.
What it does: It Receives a CSV file and a gateway name (paddle or stripe) through a webhook - Validates every row first. If any row has an error, nothing is created and you get the row errors back
Creates one product and one price per row (one-time, or recurring with a day/week/month/year interval)
Returns a JSON report with the product and price IDs and any per-row failures
Handles flexible CSVs: different column names, comma/semicolon/tab/pipe delimiters, and prices like €12,50 or $1,250.00
Requirements:
A Paddle sandbox API key and/or a Stripe test-mode secret key (saved as Bearer Auth credentials in n8n)
A way to send a multipart form, such as curl or a small upload page
How to try it
Add your Bearer Auth credential on the Paddle and/or Stripe HTTP Request nodes
Review the defaults in the “Set Default Configuration” node
Activate the workflow and send a POST: curl -F “csvFile=@catalog.csv” -F “gateway=stripe” Minimum CSV columns: a product name and a price. Optional: category, type, description, interval, currency.
Nice, validating every row before creating anything is the step most imports skip. Two things I’d add, since re-running an import is where these usually go wrong:
Make it safe to re-run. If a run fails at row 40 of 100, the first 39 products already exist and a retry creates them twice. On Stripe you can send an Idempotency-Key header with each create request (for example a hash of the row), and set a lookup_key on each price so you can check whether it already exists. On Paddle you can put your own row ID in custom_data and list existing products first to skip them.
Zero-decimal currencies. Stripe’s unit_amount is in the smallest unit, so €12,50 becomes 1250, but JPY or KRW must not be multiplied by 100. Worth adding a test row for that to your sample CSV.
Do you also handle products that were removed from the CSV (archive them), or is it create-only for now?
Thanks for the feedback and yes, you’re right, it’s create-only for now, so a retry after a failure would duplicate the products that were already created. I’ll make it safe to re-run, with a stable key per row so existing products get skipped instead of created again (product ID / lookup_key / Idempotency-Key on Stripe, custom_data on Paddle).
JPY, KRW, CLP and VND are already sent without the ×100. Your comment made me realize the list isn’t complete, though, and the three-decimal currencies (KWD, BHD…) need handling too. I’ll fix that and add test rows to the sample CSV.
for the removed products, an optional sync mode that archives them is a good idea. I’ll look into it.
I’ll work on these and post an update here when it’s ready
