Can flow continue running after node Remove Duplication?
I want to run some node after “Remove Duplication” but my flow stop even though i chose to continue when i got the error in setting
“nodes”: [
“parameters”: {
“pollTimes”: {
“item”: [
“mode”: “everyMinute”
“documentId”: {
“__rl”: true,
“value”: “https://docs.google.com/spreadsheets/d/12xjQsTXW4rV676z-2bdRjDxxNiquiPc7CBCgw3rvuaU/edit?gid=1771867503#gid=1771867503”,
“mode”: “url”
“sheetName”: {
“__rl”: true,
“mode”: “url”
“event”: “rowAdded”,
“options”: {}
“type”: “n8n-nodes-base.googleSheetsTrigger”,
“typeVersion”: 1,
“position”: [
0,
0
“id”: “6f717bd4-531c-49c7-b385-4c0fee1b2f77”,
“name”: “Google Sheets Trigger”,
“credentials”: {
“googleSheetsTriggerOAuth2Api”: {
“id”: “2bX4WrbKrxeA1dk9”,
“name”: “Google Sheets Trigger account”
“parameters”: {
“jsCode”: “// Loop over input items and add a new field called ‘myNewField’ to the JSON of each one\nfor (const item of $input.all()) {\n item.json.myNewField = 1;\n}\n\nreturn $input.all();”
“typeVersion”: 2,
“position”: [
220,
0
“id”: “4812d494-c565-49ec-8862-08e7eb826fe5”,
“name”: “Code”
“parameters”: {
“documentId”: {
“__rl”: true,
“mode”: “url”
“sheetName”: {
“__rl”: true,
“value”: “https://docs.google.com/spreadsheets/d/12xjQsTXW4rV676z-2bdRjDxxNiquiPc7CBCgw3rvuaU/edit?gid=0#gid=0”,
“mode”: “url”
“options”: {}
“type”: “n8n-nodes-base.googleSheets”,
“typeVersion”: 4.5,
“position”: [
440,
0
“id”: “f77ce861-2c60-452a-8f11-47b3893f80a6”,
“name”: “Google Sheets Source”,
“credentials”: {
“googleSheetsOAuth2Api”: {
“id”: “g43TUJE5IaAcvl9Y”,
“name”: “Google Sheets account”
“parameters”: {
“operation”: “appendOrUpdate”,
“documentId”: {
“__rl”: true,
“value”: “https://docs.google.com/spreadsheets/d/1ohT9IyMwAYD71N2L5M6-QFTowazMYWhlcqKzDsJo_cI/edit?gid=1378657116#gid=1378657116”,
“mode”: “url”
“sheetName”: {
“__rl”: true,
“value”: “https://docs.google.com/spreadsheets/d/1ohT9IyMwAYD71N2L5M6-QFTowazMYWhlcqKzDsJo_cI/edit?gid=0#gid=0”,
“mode”: “url”
“columns”: {
“mappingMode”: “defineBelow”,
“value”: {
“ID Target”: “={{ $json.ID }}”,
“Tên Target”: “={{ $json[‘Tên’] }}”,
“Nội dung Targe”: “={{ $json[‘Nội dung’] }}”,
“Link Target”: “={{ $json.Link }}”,
“Time created”: “={{ $now.setZone(‘Asia/Ho_Chi_Minh’).toFormat(‘yyyy-MM-dd HH:mm:ss’) }} \n”
“matchingColumns”: [
“ID Target”
“schema”: [
“id”: “ID Target”,
“displayName”: “ID Target”,
“required”: false,
“defaultMatch”: false,
“display”: true,
“type”: “string”,
“canBeUsedToMatch”: true,
“removed”: false
“id”: “Tên Target”,
“displayName”: “Tên Target”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “Nội dung Targe”,
“displayName”: “Nội dung Targe”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “Link Target”,
“displayName”: “Link Target”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “Time created”,
“displayName”: “Time created”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“options”: {}
“typeVersion”: 4.5,
“position”: [
660,
0
“id”: “551f1db5-52c1-4399-9e67-cb3476bf801c”,
“name”: “Google Sheets Target”,
“credentials”: {
“parameters”: {
“operation”: “removeItemsSeenInPreviousExecutions”,
“logic”: “removeItemsUpToStoredDate”,
“dateDedupeValue”: “={{ $json[‘ID Target’] }}”,
“options”: {}
“type”: “n8n-nodes-base.removeDuplicates”,
“typeVersion”: 2,
“position”: [
880,
0
“id”: “bb8869ed-bdde-4808-9424-7db3ce16a114”,
“name”: “Remove Duplicates sau khi có dòng mới”,
“onError”: “continueRegularOutput”
“parameters”: {
“operation”: “clearDeduplicationHistory”,
“options”: {}
“typeVersion”: 2,
“position”: [
1320,
0
“id”: “f27ed74d-0b25-4d31-95c9-a6a69212811d”,
“name”: “Remove Duplicates của cả bảng”
“parameters”: {
“amount”: 15
“type”: “n8n-nodes-base.wait”,
“typeVersion”: 1.1,
“position”: [
1100,
0
“id”: “dcdd3c14-38cf-4542-9519-08ce0eb0ebb0”,
“name”: “Wait”,
“webhookId”: “dae4880b-9836-420d-809e-5528a508a1c1”
“connections”: {
“Google Sheets Trigger”: {
“main”: [
“node”: “Code”,
“type”: “main”,
“index”: 0
“Code”: {
“main”: [
“node”: “Google Sheets Source”,
“type”: “main”,
“index”: 0
“Google Sheets Source”: {
“main”: [
“node”: “Google Sheets Target”,
“type”: “main”,
“index”: 0
“Google Sheets Target”: {
“main”: [
“node”: “Remove Duplicates sau khi có dòng mới”,
“type”: “main”,
“index”: 0
“Remove Duplicates sau khi có dòng mới”: {
“main”: [
“node”: “Wait”,
“type”: “main”,
“index”: 0
“Remove Duplicates của cả bảng”: {
“main”: [
“Wait”: {
“main”: [
“node”: “Remove Duplicates của cả bảng”,
“type”: “main”,
“index”: 0
“pinData”: {}
  • **n8n version: cloud version
  • Database (default: SQLite): Google sheet
Hey @ti_saigon , what error did you get? You might need to have “Always Output Data” enabled instead (or alongside).
