Hello n8n Team,
I’m currently running n8n on my own server using Docker (self-hosted). I’m considering purchasing the Pro plan from n8n to access the additional features and support.
Before proceeding, I’d like to clarify:
If I purchase the Pro plan, can I use the same Pro features and benefits on my self-hosted Docker instance, or is the Pro plan only applicable to the cloud-hosted service on n8n.cloud?
If the Pro plan is not applicable to self-hosted deployments, is there a separate plan or licensing option that enables Pro/Enterprise features and support for self-hosted installations?
I want to ensure that I make the right choice based on my setup.
Looking forward to your guidance.
Thank you!
— Imran
