Can posible auto add label when workflow running?
Hello everyone, i want ask someting. is posible to add automatic label when run the workflow ? becuase my n8n run 1000+ excution per day, hard to see when not have label. so its there have solution for handle that ?
obrigado :slight_smile:
hello @Agellls
there is a special node called Execution Data, which may add highlights to the execution. Labels are more for the manual labelling.
