Can some one help me with this? My appointment booking workflow books appointments correctly sometimes but randomly does not
I am trying to run the workflow below which takes the following payload from the webhook and schedules an appointment in google calendar -
“Full_Name”: “Rohit Ramesh”,
“Phone”: “+14123788780”,
“preferred_time”: “August 16th, 9 AM”
However, the appointment is booked correctly sometimes and sometimes it says slot is booked even if its not. The workflow runs succesfully though so no issues there.
“nodes”: [
“parameters”: {
“sessionIdType”: “customKey”,
“sessionKey”: “={{ $json[“sessionId”] || $json[“Phone”] || $json[“Full_Name”] || $executionId }}”,
“contextWindowLength”: 1
“type”: “@n8n/n8n-nodes-langchain.memoryBufferWindow”,
“typeVersion”: 1.3,
“position”: [
-32,
1008
“id”: “69e9e526-6048-4954-ab15-54cff047e668”,
“name”: “Simple Memory”,
“notesInFlow”: false
“parameters”: {
“model”: {
“__rl”: true,
“value”: “gpt-4-turbo”,
“mode”: “list”,
“cachedResultName”: “gpt-4-turbo”
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.lmChatOpenAi”,
“typeVersion”: 1.2,
“position”: [
-160,
1008
“id”: “a59c382e-7033-4090-808e-ccb89c919f79”,
“name”: “OpenAI Chat Model1”,
“credentials”: {
“openAiApi”: {
“id”: “MTFgzH1dOlBNhqrG”,
“name”: “OpenAi account 2”
“parameters”: {
“operation”: “getAll”,
“calendar”: {
“__rl”: true,
“value”: “[email protected]”,
“mode”: “list”,
“cachedResultName”: “[email protected]
“returnAll”: true,
“timeMax”: “={{ $now.plus({ week: 4 }) }}”,
“options”: {
“timeZone”: {
“__rl”: true,
“value”: “America/New_York”,
“mode”: “list”,
“cachedResultName”: “America/New_York”
“type”: “n8n-nodes-base.googleCalendarTool”,
“typeVersion”: 1.3,
“position”: [
96,
1008
“id”: “b0a190b9-99c1-45ac-85a7-9bf38d86954d”,
“name”: “get_calendar”,
“credentials”: {
“googleCalendarOAuth2Api”: {
“id”: “EaWwgOOIsYr9rgqq”,
“name”: “Google Calendar account 2”
“parameters”: {
“respondWith”: “allIncomingItems”,
“options”: {}
“type”: “n8n-nodes-base.respondToWebhook”,
“typeVersion”: 1.4,
“position”: [
432,
784
“id”: “d2762261-7936-4074-b5d9-078ab989331c”,
“name”: “Respond to Webhook”
“parameters”: {
“calendar”: {
“__rl”: true,
“mode”: “list”,
“start”: “={{ /n8n-auto-generated-fromAI-override/ $fromAI(‘Start’, , 'string') }}", "end": "={{ /*n8n-auto-generated-fromAI-override*/ $fromAI('End', , ‘string’) }}”,
“additionalFields”: {
“description”: “={{ /n8n-auto-generated-fromAI-override/ $fromAI(‘Description’, , 'string') }}", "summary": "={{ /*n8n-auto-generated-fromAI-override*/ $fromAI('Summary', , ‘string’) }}”
“typeVersion”: 1.3,
“position”: [
224,
1008
“id”: “eb4c4e3f-760d-42e2-9c8b-b4dcb1138961”,
“name”: “post_calendar”,
“alwaysOutputData”: true,
“credentials”: {
“parameters”: {
“httpMethod”: “POST”,
“path”: “Schedule-appointment”,
“responseMode”: “responseNode”,
“options”: {}
“type”: “n8n-nodes-base.webhook”,
“typeVersion”: 2.1,
“position”: [
-384,
784
“id”: “888a7996-21fb-4645-aaba-eadec6f64909”,
“name”: “Webhook”,
“webhookId”: “08f1e90c-ed98-459d-a643-3c2084285c9b”
“parameters”: {
“promptType”: “define”,
“text”: “=Hi, I would like to schedule an appointment.\n\nFull Name: {{ $json.body.Full_Name }}\nPhone: {{ $json.body.Phone }}\nPreferred Time: {{ $json.body.Preferred_time }}\nOther Notes: {{ $json.body.Other_information }}\n\nAlready Booked Slots:\n{{ $json[“response”].map(e => e.start.dateTime + " to " + e.end.dateTime).join(“\n”) }}\n\nIf the preferred slot is not available, schedule an alternative. Otherwise, suggest the next closest available slot between 9 AM and 5 PM.”,
“options”: {
“systemMessage”: “# Task\nYou are a scheduling assistant. Your job is to book appointments using Google Calendar.\n\n# Rules\n- Call get_calendar first to retrieve existing appointments\n- Check if the user’s preferred time is available\n- If available, schedule the event for 30 mins\n- If not, suggest the nearest available time between 9 AM and 5 PM\n- Use post_calendar only after confirming availability”
“type”: “@n8n/n8n-nodes-langchain.agent”,
“typeVersion”: 1.9,
“position”: [
-48,
784
“id”: “68b824cd-1b4d-4f4f-81fc-987f499d2334”,
“name”: “AI Agent”,
“connections”: {
“Simple Memory”: {
“ai_memory”: [
“node”: “AI Agent”,
“type”: “ai_memory”,
“index”: 0
“OpenAI Chat Model1”: {
“ai_languageModel”: [
“node”: “AI Agent”,
“type”: “ai_languageModel”,
“index”: 0
“get_calendar”: {
“ai_tool”: [
“node”: “AI Agent”,
“type”: “ai_tool”,
“index”: 0
“post_calendar”: {
“ai_tool”: [
“node”: “AI Agent”,
“type”: “ai_tool”,
“index”: 0
“Webhook”: {
“main”: [
“node”: “AI Agent”,
“type”: “main”,
“index”: 0
“AI Agent”: {
“main”: [
“node”: “Respond to Webhook”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “34ced75dd427ccf2d045c820903395fe9550d469232d0c251dd21db4b39a9775”
