Can’t Access Array Element in GetMessages Using Dynamic Index from Loop Over Items
I’m using the Loop Over Items node to iterate through a list of inputs with batchSize = 1.
In each iteration, I want to access a specific item inside an array returned by GetMessages1, using the current loop index — and send that item’s content via Telegram3.
However, I can’t access the correct indexed value dynamically using the current loop index.
Each Telegram message ends up undefined, empty, or incorrectly repeats values from previous iterations.
No error in the workflow execution itself, but Telegram3 fails to send expected content because it receives undefined or the wrong item from GetMessages1.
  • n8n version: 1.82.1
  • Database (default: SQLite): PostgreSQL
  • Operating system: Linux (Pop!_OS)
Hi @Zafer_KAHRAMAN,
If you could share the code of your workflow it would help us to debug it.
In the meantime please find bellow an example with a Loop Over Items.
