Cancel plan but keep workspace?
Can I “pause” payments for my Starter Plan and resume using it in a few months?
Hi @tomtom,
Good question!
Unfortunately we don’t have a subscription “pause” setting available at the moment.
The best way to take a break would be to export your workflows and credentials and keep them stored in your care until you decide to come back. Then, you can just re-sign up to a new instance and import them back.
You can do this through the … menu at the top right corner of your screen, by selecting Download, and later, when importing, selecting Import.
There are also some templates like this one that help you automatically backup your work! Nightly n8n backup to Dropbox | n8n workflow template
Hope this helps! :dizzy:
