Since the recent update I am no longer able to select Expression as a body parameters or Query Parameters type in the HTTP Request Node.
This occurs when selecting Send Body to On
Specify Query Parameters to Using JSON
Then trying to click Expression as the body type
There is no error message or errors captured in the console.
I have 3 different installations of n8n and it occurs on all of them so not isolated to one.
- n8nVersion: 1.75.2
- platform: docker (self-hosted)
- nodeJsVersion: 20.18.1
- database: sqlite
n8n
2
- n8n version:
- Database (default: SQLite):
- Operating system:
I can see that this has been addressed in 1.76.0 unless there is a workaround in the meantime.
system
Closed
4
