Can't figure out session ID issue – value format not supported
Hi there! I’m a total noob, and I’m trying to figure out how the Simple Memory node works.
The issue I’m running into is with the sessionId field — I’m using {{ $json.body.message.chat.id }}, but the Telegram chat ID that gets generated throws an error.
For example:
“The value ‘74255848’ is not supported”
What format is actually supported for the sessionId?
core
  • n8nVersion: 1.84.1
  • nodeJsVersion: 20.18.3
  • database: sqlite
  • executionMode: regular
  • concurrency: -1
  • license: enterprise (production)
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
hello @200comp
Please, share the workflow. I can’t find the node which you are using. But I suppose it asks not for the telegram’s chat id.
You can select all nodes with ctrl+a, copy it with ctrl+c. Then past the content here after pressing button </> with ctrl+v.
