Can't pass along info from past nodes anymore
I’m trying to pass along information from past nodes to respond to a webhook, or even just forward as a webhook somewhere else
[invalid syntax]“] }}
[invalid syntax]”] }}
“={\n "Response": {\n "Subject":"SUBJECT",\n "Message":"MESSAGE"\n }\n}\n\n{{ $json["customField"]["{{ $json.customFields[1].id }}"] }}\n{{ $(‘Fix subject for errors’).item.json["customField"]["{{ $json.customFields[1].id }}"] }}\n”
  • n8n version: 1.9.2
  • Database (default: SQLite): Default database in docker image
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Unknown
  • Operating system: Linux/Cyberpanel/Docker
p.s. this used to work just perfectly fine on version 0.241
Hi @bonelli :wave:
It’s a little difficult without having some JSON as an example, but I can probably point you in the right direction :slight_smile: In your code nodes, instead of:
$node['Spintax Content'].json.parsed_string;
You’d need something like:
$('Spintax Content').item.json.parsed_string
If you fix this up for any time you’re calling a node, that should also fix up the error :bowing_man:
