Cause of SQLite Errors?
So I upgraded to 1.87.0 a few days ago and my workflows started failing due to SQLite errors (example below). I was going to submit a bug report but while digging noticed my database file had risen to about 10 gigs in size… turns out I’d never enabled pruning.
Before I waste anyone’s time with an actual bug report, is this the likely cause? I’ve since enabled pruning and vacuuming on startup, which dropped the size to a much more manageable 1 gig. No errors yet, but we’ll see.
  "execution": {
    "id": "64050",
    "url": "url/workflow/cbxfqmEB2YSLsyWn/executions/64050",
    "error": {
      "query": "SAVEPOINT typeorm_-2",
      "driverError": {
        "errno": 1,
        "code": "SQLITE_ERROR",
        "__augmented": true
      "errno": 1,
      "__augmented": true,
      "message": "SQLITE_ERROR: near \"-\": syntax error",
      "stack": "QueryFailedError: SQLITE_ERROR: near \"-\": syntax error\n    at handler (/usr/local/lib/node_modules/n8n/node_modules/@n8n/typeorm/driver/sqlite/SqliteQueryRunner.js:88:37)\n    at replacement (/usr/local/lib/node_modules/n8n/node_modules/sqlite3/lib/trace.js:25:27)\n    at Statement.errBack (/usr/local/lib/node_modules/n8n/node_modules/sqlite3/lib/sqlite3.js:15:21)"
    "lastNodeExecuted": "Check Network",
    "mode": "trigger"
  "workflow": {
    "id": "cbxfqmEB2YSLsyWn",
    "name": "workflow name"
hi,
Can you mark your own answer as solution please and close this.
If something pops up, you can still launch something else
Thanks
J.
