I’m reading data from a form (webhook) that provides fields with 1 or 0 depending if a box is checked. I need to give this to Google Sheets as TRUE or FALSE for checkboxes to work properly, but I can’t figure out how to use an expression to transform the value. I’ve looked up a few similar-ish forum posts but didn’t find anything useful.
- n8n version: latest
- Database you’re using (default: SQLite): Unknown
- Running n8n with the execution process [own(default), main]: own(?)
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: docker, via Cloudron
