I was wondering if there was a way to replace the default "♥"
confirmation message in the terminal console when a workflow successfully runs? In addition, is there also a way to print to the terminal being used to run n8n? In my case, I’m running n8n in Visual Studio locally, so the "♥"
prints where the node is currently running — Would be nice to be able to print your own confirmation messages. Thanks!
- n8n version: 0.207.1
- Database you’re using (default: SQLite): Default
- Running n8n with the execution process [own(default), main]: Default
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: npm
