Is there a simple method to connect n8n to my ChatGPT Plus subscription, so that I don’t have to use API calls? On opencode, instead of using AI tokens (and paying on top of your plus subscription) you can simply connect opencode to your ChatGPT Plus subscription.
This will ease the AI integrations. I’m mainly using n8n deterministically for now because of this.
n8n’s OpenAI node authenticates with an API key, not a ChatGPT Plus subscription, so there’s no way to reuse a Plus account directly. You’ll need to create an API key at platform.openai.com and use that in n8n’s OpenAI credentials. The API is billed per token separately from your Plus subscription. If cost is the concern, you can set usage limits and pick cheaper models like gpt-4o-mini for routine steps.
I guess it’s a basic feature that n8n should have, knowing that the alternatives already have it and it simplifies AI implementation. No one wants to set up an API that you have to constantly monitor in order to not consume all tokens.
I get the frustration — it does feel like it should just work, since you are already paying for Plus. The reason it doesn’t is that Plus and the API are really two separate products, even though they are both from OpenAI.
Plus is a subscription for the ChatGPT app and website. The API, at platform.openai.com, is a separate developer service with its own billing, and that is what n8n’s OpenAI node and AI Agent node talk to. There is no Plus login or OAuth option in n8n to connect, so a Plus subscription on its own cannot be used as a credential.
In n8n, create an OpenAI credential with that key.
Use it in the OpenAI node or an AI Agent node, and start with a smaller model for routine steps.
You can keep Plus for everyday chatting and use the API only inside n8n — they do not share quota, and the API is billed per use, so you can set usage limits in the OpenAI dashboard if you want a hard ceiling. I know that is not the one-subscription answer you were hoping for, but it is the supported route in n8n, and it keeps your deterministic workflows separate from your chat usage.
OpenAI does support using an eligible ChatGPT Plus or Pro plan in participating apps through Sign in with ChatGPT. Each app needs to implement that connection. n8n’s built-in OpenAI credential currently supports API keys, so there isn’t a Plus login option there.
If you use n8n Cloud Starter or Pro, you can select Use Gateway credits in a supported node’s credential field to skip setting up a provider account and API key. This uses a separate prepaid n8n balance and doesn’t spend your Plus allowance.
n8n’s built-in OpenAI Chat Model node currently requires an API-key and doesn’t offer that Plus sign-in.
If you’re self-hosting, a possible bridge is Codex CLI.
Install it and sign in with your ChatGPT account in the environment that actually runs n8n, including the container or worker if applicable.
An enabled Execute Command node can then call Non-interactive mode | ChatGPT Learn
which reuses that login and draws on your Codex plan allowance, subject to its usage limits.
This is a separate command step, rather than a native AI Agent model connection.
Execute Command is disabled by default and isn’t available on n8n Cloud.
Oh wait are you self-hosting or using Cloud?
I use the self hosted version. What I’m suggesting, is that n8n’s value is in it’s simplicity. Therefore, Chatgpt Plus usage inside n8n (just like other alternatives like Opencode,etc) should also be simple.
Understood @Sebastian_Arias. A built-in “Continue with ChatGPT” option in the OpenAI credential would let you connect your Plus account from n8n directly. For anyone following, Sebastian already shared his use case on the existing feature request here.
hey sebastian, is using your existing chatgpt plus subscription the hard requirement, or is the main thing keeping inference costs low?
i’m testing a small http bridge for existing n8n workflows. it uses a separate inference provider and doesn’t draw on your plus subscription. if you’re open to that, i can show you the request and response once i’ve verified the full path on my side.
hey sebastian, that clears it up. you want to use the subscription you already have without managing a second set of credentials. the groq bridge i mentioned doesn’t do that.
since you’re self-hosting, i found an official sign-in route worth testing. i’d start with one workflow step where you sign in with chatgpt, send a prompt from n8n, and get the answer back without entering a model API key. i haven’t verified that full path yet.
what’s the first thing you’d want that step to do in a workflow you already run?
hey Sebastian, that makes sense. if the goal is configure once and get back to work, a credential-first approach is definitely preferable.
one distinction though: the credential handles authentication, while the integration still needs to know which operation to call and how to handle the response.
what’s the specific ChatGPT operation you’re trying to run from n8n? i’m curious whether the existing nodes cover it or whether there’s actually a missing piece worth building.
