Chatwoot Partially Running
I have installed chatwoot and n8n via docker template in hostinger , but my chatwoot-base-1 shows exited , but i am receivng messages and all , but why this exited issue , is this ok ? or how to fix it?
Hi @Burhan_Nathdwara i suppose below will give you a better help:
Adding a bit more from my point of view:
Check the exit code with docker ps -a.
Review the docker-compose.yml / template to confirm whether chatwoot-base-1 is meant to be a one-off service.
If needed, restart or recreate just that service to see whether it exits again for the same reason.
If the exit code is 0 and the core Chatwoot services remain healthy, there is likely nothing to fix. In that case, this looks more like expected container behavior than an actual runtime issue.
