i’m trying to check a workflow is running but even running it returns the value as “isActive”: false
Did I do some wrong configuration?
thank you for your help
If you just want to check the current workflow is running, then change the isActive: executions.length > 1
to isActive: executions.length > 0
You can also use $workflow.id
for the comparison instead of a static value: execution.workflowId === $workflow.id
this is exactly what i was looking for, thank you very much
Hello,
Thanks for these answers.
Could someone details what is the final code?
