Hi i’d like to have an AI that can help me build workflows like an AI copilot ot build my N8N worklows. The idea is that i’ll feed it an exhaustive context with described features and use case and we build it together, kind of shoulder to shoulder. An ai that would understand the context and what i’m doing and where i’m at. Anyone has something like this to recommend me ? Thanks
you can use N8N Ai which you will get in your canva but it has limitations it does not support shoulder to shoulder because it is very bad at remembering details you can get simple templates ready however , there is a way around using external AI’s if you want I can help you with that
