I run docker stack with n8n, n8n-worker, postgresdb and redis. It was all fine until i upgraded to 2.0.3. I have added n8n-runner as its needed for code node.
After upgrade of n8n to 2.0.3 with task runners implemented, i get “Code node task was not matched to a runner within the timeout period” for code node for both python and javascript.
Task request timed out after 60 seconds
Your Code node task was not matched to a runner within the timeout period. This indicates that the task runner is currently down, or not ready, or at capacity, so it cannot service your task.
If you are repeatedly executing Code nodes with long-running tasks across your instance, please space them apart to give the runner time to catch up. If this does not describe your use case, please open a GitHub issue or reach out to support.
If needed, you can increase the timeout using the N8N_RUNNERS_TASK_REQUEST_TIMEOUT environment variable.
Error: Task request timed out after 60 seconds at LocalTaskRequester.requestExpired (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:304:17) at LocalTaskRequester.onMessage (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:272:10) at TaskBroker.handleRequestTimeout (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:115:50) at Timeout.<anonymous> (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:102:9) at listOnTimeout (node:internal/timers:588:17) at processTimers (node:internal/timers:523:7)
- n8n version: 2.0.3
- Database (default: SQLite): postgresdb
- **n8n EXECUTIONS_PROCESS setting (default: own, main): **
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker swarm stack
- Operating system: Ubuntu
- Here is my docker-compose.yml
version: '3.8'
services:
postgres:
image: postgres:16
restart: always
networks:
- traefik_web
environment:
- POSTGRES_USER=xxxxx
- POSTGRES_PASSWORD=yyyyyyyy
- POSTGRES_DB=n8n
volumes:
- /opt/nfs/n8n_db:/var/lib/postgresql/data
healthcheck:
test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
interval: 5s
timeout: 5s
retries: 10
redis:
image: redis:6-alpine
restart: always
networks:
- traefik_web
volumes:
- /opt/nfs/n8n_redis:/data
healthcheck:
test: ['CMD', 'redis-cli', 'ping']
interval: 5s
timeout: 5s
retries: 10
n8n:
restart: always
image: n8nio/n8n:2.0.3
container_name: n8n
environment:
# --- Database Connection Settings ---
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=n8n
- DB_POSTGRESDB_USER=xxxxx
- DB_POSTGRESDB_PASSWORD=yyyyyyyy
# --- General Settings ---
- EXECUTIONS_MODE=queue
- N8N_ENCRYPTION_KEY=5QMMhD6hAvy6usEk
- OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS=true
- N8N_SECURE_COOKIE=false
- NODES_EXCLUDE="[]"
- N8N_METRICS=true
# --- Logging ---
- N8N_LOG_LEVEL=debug
- N8N_LOG_OUTPUT=console,file
- N8N_LOG_FILE_LOCATION=/home/node/.n8n/logs/n8n.log
- N8N_LOG_FILE_SIZE_MAX=50
# --- Redis Settings ---
- QUEUE_BULL_REDIS_HOST=redis
- QUEUE_HEALTH_CHECK_ACTIVE=true
# --- Runner Config ---
- N8N_RUNNERS_ENABLED=true
- N8N_RUNNERS_MODE=external
- N8N_RUNNERS_BROKER_LISTEN_ADDRESS=0.0.0.0
- N8N_RUNNERS_AUTH_TOKEN=X5tP9qR3F8jX0
- N8N_NATIVE_PYTHON_RUNNER=true
links:
- postgres
- redis
volumes:
- /opt/nfs/n8n:/home/node/.n8n
- /opt/nfs/n8n_app_data:/data
ports:
- 5678:5678
networks:
- traefik_web
n8n-runner:
image: n8nio/runners:2.0.3
container_name: n8n-runner
environment:
- N8N_RUNNERS_TASK_BROKER_URI=http://n8n:5679
# --- Logging ---
depends_on:
- n8n
networks:
- traefik_web
n8n-worker:
restart: always
environment:
- GENERIC_TIMEZONE=Europe/Amsterdam
- TZ=Europe/Amsterdam
# --- Logging ---
links:
- postgres
- redis
volumes:
command: worker
networks:
- traefik_web
networks:
traefik_web:
external: true
