I’m getting this error on every execution of a Code node, even with very small item counts (5–20 items):
Error: Task request timed out after 60 seconds
at LocalTaskRequester.requestExpired (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:305:17)
at LocalTaskRequester.onMessage (/usr/local/lib/node_modules/n8n/src/task-runners/task-managers/task-requester.ts:273:10)
at TaskBroker.handleRequestTimeout (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:124:50)
at Timeout. (/usr/local/lib/node_modules/n8n/src/task-runners/task-broker/task-broker.service.ts:110:9)
at listOnTimeout (node:internal/timers:605:17)
at processTimers (node:internal/timers:541:7)
What I’ve already ruled out:
- Not a data volume issue — fails consistently even with just 5 items via a Limit node before the Code node
- Not an inefficient code issue — the code is simple object mapping + one regex on a short string, no loops, no external calls (code below)
- Not a malformed JSON issue — the data has already passed through several standard nodes (Split Out, Filter, IF) without any errors before reaching the Code node
