Hello Team,
I am using the Code node to prevent the duplicate upload of contacts in Mailchimp. I am using JavaScript code in the node.
However, I am facing a few issues:
- The
staticData
is not working. - The previous workflow values are not working.
- After the
Set new last execution timestamp
node ends, I want to assign thestaticData.lastExecution
value to theGet last execution timestamp
item.lastExecution and exit the workflow. I couldn’t find a suitable node for this. Can you please suggest one?
Thank you.
No
Note the Workflow is in active stage.
- **n8n version:0.222.0
- **Database (default: SQLite):latest
- **n8n EXECUTIONS_PROCESS setting (default: own, main):own
- **Running n8n via (Docker, npm, n8n cloud, desktop app):docker
- **Operating system:MAC
