The idea is:
Combine the input and output of a Node directly in the node. The idea would be to specify an output transformation using the node’s default output and the input.
My use case:
This is a feature in AWS Step Functions that I miss. I tend to build state as the workflow executes. I know we can access previous node’s data but this doesn’t always work very well. I tend to use Code nodes to apply output from things like HTTP nodes by referencing the previous node. Being able to specify an output transformation something like:
{ …$input, result: $output }
Would save me a lot of time. This is simplistic but providing a templating language could allow for manipulating the state more easily without relying on looking up previous nodes. I have run into problems when splitting arrays and that sort of thing.
But maybe I am just not doing something properly in n8n. But this is how I think about it when building workflows.
I know for me it would save a lot of time and make my workflows easier to look at. Even just being able to specify a field name in the input where the output should go and then passing the entire thing out would help me tremendously.
This is how it works in Step Functions: Specifying state output using ResultPath in Step Functions - AWS Step Functions
I may be willing to help with this.
