Hello everybody,
I’m currently trying to setup a workflow which uses Httpx to fetch some URLs.
I can execute the command flawlessly inside the docker container of n8n (tool is available etc.) but if I run the command inside an “execute command” node, the command won’t finish/is stuck executing. All other command seem to work, just the httpx command seems to be stuck.
I can execute the following command flawlessly inside the n8n docker container:
time httpx -u https://google.com -sc -cl -title -td -ip -silent
https://google.com [301] [134] [301 Moved Permanently] [<redacted>] [Amazon ELB,Amazon Web Services]
real 0m1.746s
user 0m1.579s
sys 0m0.154s
(time was used to showcase, that the command executed quickly)
But inside n8n, it is stuck and won’t finish executing.
I don’t get any error or stacktrace, it just keeps on “executing”.
Please let me know, if you can help me somehow, how to debug this behavior.
Node is stuck and keeps executing.
Expected output:
https://google.com [301] [134] [301 Moved Permanently] [] [Amazon ELB,Amazon Web Services]
- n8n version: n8n@1.119.2
- Database : PostGres
- Running n8n via: Custom Docker Image with npm
- Operating system: Ubuntu 22.04.5 LTS
