How to automate content publishing and optimization on TikTok with n8n?
Hello everyone,
I’m new to n8n and I’d like to automate the management and optimization of my TikTok page (scheduling posts, tracking performance, etc.).
Does anyone have any advice, guides, or workflow examples for connecting n8n to TikTok?
Thank you in advance for your help
Hey @Yann_Gautier_Kouakou, while you wait for a response, here are some things that might help:
Suggested resources
Docs:
Forum:
@Glorious - you’ve helped with similar issues before, can you take a look?
Hey @Yann_Gautier_Kouakou Welcome to the N8n community,
There’s no TikTok node in n8n, so everything goes through the HTTP Request node and TikTok’s own API, and posting has a catch worth knowing before you build. TikTok’s Direct Post API keeps anything an unaudited app publishes private, and its guidelines list “a utility tool to help upload contents to the account(s) you or your team manages” as a use that won’t pass the audit. For your own page the realistic route is the Upload flow: n8n sends the video to /v2/post/publish/inbox/video/init/, it lands in your TikTok inbox as a draft, and you tap the notification to publish. Your developer app still needs the video.upload scope approved first.
Tracking is the easier half. With the video.list scope approved, a scheduled workflow can pull view, like, comment and share counts from TikTok’s v2 video endpoints and log them to a Google Sheet.
if you don’t want to use the official TikTok API, then I guess you can explore Blotato, as that’s a platform which can easily enable you automate posting on TikTok
Here is the link for Blotato, Let me know if this helps.
Great breakdown from @Deepankar on the audit gotcha — I’d add the parts that usually bite people between “it works in Postman” and “it runs in production”, since I’ve built this exact pipeline for clients.
The upload flow is really three HTTP calls, not one:
  1. POST /v2/post/publish/inbox/video/init/ to get an upload_url and publish_id
  2. PUT your video bytes to that upload_url in chunks — TikTok uses FILE_UPLOAD_CHUNKED, so send Content-Range per chunk; pushing a big file in a single PUT is the most common cause of silent timeouts
  3. POST /v2/post/publish/status/fetch/ with the publish_id to poll until the draft is ready in your inbox
In n8n that maps to three HTTP Request nodes sharing one OAuth2 credential. That last part matters: TikTok access tokens are short-lived, so use n8n’s OAuth2 credential type with the refresh flow rather than pasting tokens into headers. The day you hardcode a token is the day your schedule breaks overnight.
Two production lessons worth designing around:
The inbox draft flow is a ceiling, not a bug. On your own account there’s no fully hands-free publish via the official API — a human taps the inbox notification. Architect it as a draft factory: batch-generate content, push drafts on a schedule, and keep a Sheet as your queue/approval list. Set that expectation in week one, because “zero-touch TikTok publishing” is where clients get disappointed.
Close the optimization loop with data you already pull. A nightly Schedule-trigger workflow can call the video.list scope endpoints, log views/likes/comments/shares per video to Google Sheets, and once a week feed an OpenAI node a digest of your top 10 videos by engagement rate asking for posting-time and hook recommendations. That’s the real “optimization” — and it runs unattended.
One more: stagger uploads through that Sheet queue instead of firing all drafts at once, or you’ll quietly hit TikTok’s rate limits.
Following up on the audit point above: the Direct Post wall applies to an app that is just a utility for your own account, but an app that has already passed the audit can post publicly for the accounts connected to it.
Disclosure: I built PostWire (postwire.io). Its TikTok app is approved for Direct Post, so you choose the visibility on each post (everyone, friends, only me), and if you choose nothing the post goes out private. From n8n you can use the community node n8n-nodes-postwire or a plain HTTP Request to the API. It also reads views and likes for each TikTok post, which covers the tracking half.
Are you on n8n Cloud or self-hosted?
Welcome to n8n @Yann_Gautier_Kouakou, and good news, this is a very doable first project once you know the two forks in the road.
Fork one is build versus connect. The official TikTok API gives you full control with no monthly tool, but you pay for it by going through TikTok’s app review before anything posts publicly. A hosted connector like the Blotato and PostWire options mentioned above absorbs that auth and audit work for you, and you still drive it from n8n with the HTTP Request node, which is often the faster path when you are starting out. Neither is wrong, it is a time versus control trade and worth deciding before you build.
If you go the official route, start in your app’s sandbox. Sandbox lets you test the whole upload flow against your own connected account before the audit, so you can learn the HTTP Request setup safely while every test post stays private. That alone removes most of the beginner frustration.
The one expectation to set early is the publishing ceiling. For a page you manage yourself, the official API does not publish fully hands-free. Your video lands in your TikTok inbox as a draft and you tap to publish it. So design it as a draft factory where n8n prepares and schedules content and you approve from your phone, rather than expecting a zero-touch button.
For the optimization half you asked about, that is actually the easier and more satisfying part. With the video.list scope you run a scheduled workflow that pulls views, likes, comments and shares into a Google Sheet, and once a week you can feed your best posts to an AI step for posting-time and hook ideas. That runs unattended and is where the real gains show up.
Disclosure, I am affiliated with Pond AI. Pond AI builds, runs and maintains custom AI agents. If it helps, we map the architecture for free and you keep that blueprint even if you build it elsewhere, and there is a 7-day refund guarantee if you later have us build it.
Do you want this to run fully on the official API, or are you open to a connector doing the TikTok side while n8n orchestrates everything?
Managing that 3-step TikTok /v2/post/publish/inbox/video/init chunk upload and status polling loop raw in HTTP Request nodes breaks constantly when token scopes expire.
If you want to skip maintaining the raw 3-call upload state machine in production, the blotato community node in n8n handles the entire TikTok video upload, captioning, and scheduling flow in a single node alongside Reels and Shorts.
Hey, i publish a bunch of flows related to socialmedia. You can find them here https://n8n.io/creators/socialrobot-io/
It will help you get started
Hi Yann,
When connecting n8n to TikTok for automated scheduling and analytics the biggest hurdle is managing the OAuth token refresh cycles and handling the strict video payload requirements. If a token expires silently your entire content calendar can fail to post without warning.
For full transparency I am affiliated with Pond AI. Pond AI builds and maintains custom social media automation architectures so you do not have to worry about undocumented API limits or broken authentication tokens yourself.
If you want to see how the pros structure this you will get a free architecture mapped out specifically for your TikTok workflow and that blueprint is completely yours to keep. If you decide to have the Pond AI team execute the heavy lifting to build it out for you every custom project comes with a 7 day refund.
Are you planning to pull raw video files from a cloud drive to post directly or are you just trying to trigger posts for videos already sitting in your TikTok drafts?
HI @Yann_Gautier_Kouakou , I’d keep publishing and performance analysis in separate workflows. Thar way, a failed analytics request won’t interrupt scheduled content.
One useful addition is a feedback loop: store each TikTok post ID alongside its publishing time, content category, and available engagement metrics. Then left n8n compile a weekly report showing which content performs best and also use those insights to guide the next batch of posts. I’d also include a manual approval step before scheduling new content.
At Pond AI, we design custom AI automation around workflows like this, with a focus on practical implementation and reliability. We offer a free architecture plan you can use with any builder, plus a 7-day refund on custom builds.
