Community Node Sync Issue: n8n-nodes-docuprox stuck at v1.0.8 (v1.0.9 published 8 days ago)
Hi n8n Team,
I am the maintainer of the community node n8n-nodes-docuprox.
I published version 1.0.9 to npm over a week ago (8 days ago), but the n8n community nodes registry within the app is still only showing version 1.0.8 as the latest.
I have verified that my package.json contains the required n8n-community-node-package keyword and the correct metadata block. Could you please help me manually trigger a refresh for this package?
npm Link: https://www.npmjs.com/package/n8n-nodes-docuprox
Current Version on npm: 1.0.9
Version showing in n8n: 1.0.8
Thank you for your help with this!
Hi @docuprox Welcome!
I think you should wait a little more… and still if that is stuck you can contact n8n with [email protected] and there you can get clear clarification about it, as there is no manual refresh trigger for the package, you can also message on #community-nodes channel on discord:
n8n
welcome to the n8n community @docuprox
You might want to join the Discord community and ask about this in the #nodes channel.
