Compare all key pairs with the same key for duplicate values, then process the record
I need to find and resolve duplicate asset records in some sort of meaningful way. My storyline goes like this:
Given an array of asset records, compare the key primary_serial for duplicate values.
Compare the entire record and copy the relevant differences to the oldest record of the duplicates. Delete the duplicate and report what it did.
I think this would be nearly the same as the “removeDuplicates” node, except it would have a way to get the data it removed out of the node so it can be assessed and merged into another record.
  • n8n version 1.7.1
  • Default database
  • Not sure how to get this infio: n8n EXECUTIONS_PROCESS setting (default: own, main):
  • n8n running in Docker on Digital Ocean.
  • Running on Ubuntu 22.04.3 LTS
Hi @russellkg, this is a tough one.
How do you identify the oldest record in your case? Do you have an example of the JSON data structure you’re working with?
