Compare Dataset Node Not Output Same Path Even It Had Same Value
Hi guys, I have an issue with the Compare Dataset node in n8n. It GETs data from a Google Sheet and our issue tracking platform via API. For example, both have an issue ticket named ‘scene1[shot1-8]’. It is supposed to output into the same path, but it does not. Any idea why it is acting like this?
  • n8n version:1.42.1
  • Database (default: SQLite):default
  • n8n EXECUTIONS_PROCESS setting (default: own, main):default
  • Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
  • Operating system:Linux
Hi @Winniepoom
Thanks for sharing your workflow here! It would have been easier to replicate if you had some data pinned with it. You think you could update that?
Hello @ria, thank you for your answer. But I don’t think I can provide you with pinned data because it contains sensitive information, and it’s also quite large (200k characters). How about I try creating mock data and see how it goes? If I encounter these issues again, I will update you and provide you with the data.
