config.headers.setContentType is not a function
Hello, I am using n8n:latest inside my vpn at Hostinger and my workflow stopped working, because my GPT-4.i-mini doesn’t answer anymore due to an error, I would like to know what should I do. Thanks
This is a known issue
Can you try this?
  1. Go ahead and save the credential anyway, just ignore the error message
  2. When you add an OpenAI node to your workflow, instead of using the default model dropdown, select your model By ID and type in the model name you need (e.g. gpt-4o, gpt-4o-mini, etc.)
Hi @Gustavo_Rincon , Welcome !
Since you’re self-hosted on Docker with :latest, i’d suggest to pin to a version before the regression. Change your Docker image from n8nio/n8n:latest to n8nio/n8n:2.18.5 (or whichever 2.18.x was your last working version) until the fix is released. That will get your workflows running again immediately.
Let me know :crossed_fingers:
