What exactly are the environment variables that I need to change for a DigitalOcean installation of n8n? I am also attempting to install this via the DO app platform.
The documentation was a bit vague:
Hi @bgschust, that would be the values from the repository that’s part of the documentation I believe. You can find the full .env file here:
Though tbh I am not sure why N8N_BASIC_AUTH_USER
and N8N_BASIC_AUTH_PASSWORD
are part of this while N8N_BASIC_AUTH_ACTIVE
isn’t (meaning basic auth is disabled anyway). My personal preference would be setting only a few variables right in the docker compose file (like so).
You can also find a full list of environment variables in our documentation in case you’d like to configure more than just the example settings:
