Hi,
i was searching for Veeva vault promomats node in the communtiy nodes, but unfortunately I did not find to install it. I need an AIP code to progress my workload. Is here someone who can support.
Thank you!
Hi,
Thank you!
Hi @Chibo,
If there is no official node for Veeva Vault and no community nodes, then your next best option is to make use of their APIs using an HTTP node. Since I have no knowledge of this website and their APIs and no access, see below potential option of finding the code’s you’re looking for.
https://www.perplexity.ai/search/i-need-help-calling-a-rest-api-phvG1JqUQ8WGEfpzjOrz7Q#0
Having browsed their APIs found below, it does seem like the Promomats is some custom application plugin to Veeva Vault and you might need to go through some trial and error to find the data. I am happy to help you build a workflow for this, however you’ll need to share some API access etc with me to help out
