Connecting to Signalwire for voice calls
Describe the problem/error/question: How can I trigger a workflow in n8n when a voice call comes into signalwire? I know there is a webhook with SignalWire, which you could create with a LaML Bin.
I am currently using zapier so I feel like there must be some way to trigger with n8n. Any help would be awesome. Thank you
Current workflow in zapier
Incoming Voice call in signalwire
Webhook to retrieve call recording data
create new excel row with call recording data
send email with call recording data
Hi @Nyeron, welcome to the community!
You can simply swap the Zapier webhook URL for a webhook URL provided by n8nā€™s webhook node, then connect the webhook node to the Excel and Gmail nodes to re-create your existing logic.
Make sure to use the test URL when building/testing your workflow (to see all data coming in in real-time) and the production URL once you have activated your workflow and want your logic to run in the background.
Thank you for the quick response I will give it a shot!
