Connection aborted when scrape using Browserless
I use the n8n 1.93 in the n8n cloud.
I fetch my sitemap xml using Browserless but when I try to fetch the a url content it aborts after 1 or 2 minutes.
My dashboard in Browserless shows that I spent my requests.
My workflow’s code is as below:
Thanks for sharing, my only thought atm, is some sort of rate limit, but then that’s not consitant with the error message you get. does it ever pull url content? or is it only pulling sitemap?
Hope you resolve soon if not already.
Thanks for your response. It only pulls the sitemap. I think the problem is the host’s IP. The site hosted by a server from Iran.
Can you test my workflow with another website?
Working from my local host here all okay. @Mostafa_Asefy did you manage to resolve it?
Best regards,
Samuel
