since 0.112.0 we have experiencing connection errors to login.microsoft.com.
Same problems persist with 0.113.0. Though there are no issues with 0.111.0
To reproduce the error .. it appears every second time when trying to reauthenticate with Oauth2 credentials (for example Microsoft Outlook API or basic OAUTH2)
2021-03-29T11:21:21.864+03:00 at TLSSocket.onError (/usr/local/lib/node_modules/n8n/node_modules/popsicle-transport-http/dist/index.js:589:35)
2021-03-29T11:21:21.864+03:00 at Object.onceWrapper (events.js:422:26)
2021-03-29T11:21:21.864+03:00 at TLSSocket.emit (events.js:315:20)
2021-03-29T11:21:21.864+03:00 at emitErrorNT (internal/streams/destroy.js:106:8)
2021-03-29T11:21:21.864+03:00 at emitErrorCloseNT (internal/streams/destroy.js:74:3)
2021-03-29T11:21:21.864+03:00 at processTicksAndRejections (internal/process/task_queues.js:80:21)
2021-03-29T11:21:21.864+03:00 (node:6) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 3)
Just wanted to inform you that I’ve created issue in popsicle-transport-http
It seems that the bug was found and was fixed in latest popsicle release!! So I’m waiting for new n8n release to test it out
P.S.: Before fixing there was one comment though about n8n and I feel the need to share it. Maybe it’s still important.
I’ve been having issues with the Outlook node timing out randomly after updating to a recent version (0.100 => 0.116.1) too, don’t know if it’s the same issue though. I have two Outlook nodes in a workflow and only one of them works successfully but the other one throws an error.
