Install clear N8N at cpanel account. Us VPS Server. and this manual How to install n8n on cpanel succesffuly - #3 by rubenalonsoes
my NodeJS Environment variables:
N8N_BASIC_AUTH_ACTIVE true
N8N_BASIC_AUTH_PASSWORD [password]
N8N_BASIC_AUTH_USER [username]
N8N_HOST localhost
N8N_LOG_LEVEL debug
N8N_PORT 5678
N8N_PROTOCOL https
N8N_PROXY_HOPS 1
N8N_PUSH_BACKEND sse
QUEUE_HEALTH_CHECK_ACTIVE true
VUE_APP_URL_BASE_API https://subdomain.mysiteurl.com/
WEBHOOK_URL https://subdomain.mysiteurl.com/
Every time get error Connection lost. or Problem running workflow.
Lost connection to the server. Use Environment variables
Error log n8n is empty. Workflow is empty to. In server log have:
App 811041 output: 2025-07-03T18:05:59.436Z | warn | Origin header is missing {“scopes”:[“push”],“file”:“index.js”,“function”:“handleRequest”}
App 811041 output: ResponseError: Invalid origin!
App 811041 output: at Push.handleRequest (/home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/n8n/src/push/index.ts:143:10)
App 811041 output: at /home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/n8n/src/push/index.ts💯10
App 811041 output: at Layer.handleRequest (/home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/router/lib/layer.js:152:17)
App 811041 output: at trimPrefix (/home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/router/index.js:342:13)
App 811041 output: at /home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/router/index.js:297:9
App 811041 output: at processParams (/home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/router/index.js:582:12)
App 811041 output: at next (/home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/router/index.js:291:5)
App 811041 output: at AuthService.authMiddleware (/home/mysite/nodevenv/node_modules/n8n/bin/n8n/22/lib/node_modules/n8n/src/auth/auth.service.ts:86:17)
App 811041 output: 2025-07-03T18:06:08.461Z [Rudder] debug: in flush
recording takes place through the Cpanel control panel, using CloudLinux WHM/cPanel, through the creation of a node js application, this option does not have the ability to make changes to server configuration files. ( nginx + apache )
Debug info
core
n8nVersion: 1.100.1
platform: npm
nodeJsVersion: 22.16.0
database: sqlite
executionMode: regular
concurrency: -1
license: enterprise (production)
storage
success: all
error: all
progress: false
manual: true
binaryMode: memory
pruning
enabled: true
maxAge: 336 hours
maxCount: 10000 executions
client
userAgent: mozilla/5.0 (windows nt 10.0; win64; x64; rv:140.0) gecko/20100101 firefox/140.0
isTouchDevice: false
