Connection lost error in n8n selft hosted AWS EC2
Hi everyone,
I’ve been running an n8n instance successfully for a long time on an AWS EC2 instance using Docker, launched inside a tmux session. The setup includes ngrok (free tier) as a reverse proxy to expose my local port (5678) over HTTPS so that I can use the n8n UI securely from anywhere.
Here’s how I set it up:
  • EC2 instance (t2.micro)
  • n8n running via Docker inside a tmux session
  • Exposed using ngrok (ngrok http 5678)
  • Base URL correctly set to the ngrok HTTPS domain
  • Environment variables (including WEBHOOK_URL, N8N_HOST, etc.) were configured and it worked beautifully
:green_circle: What Was Working Until Now
  • I could sign in to the n8n UI
  • Create and run workflows manually
  • Activate/deactivate workflows
  • WebSockets and PATCH requests worked fine
  • Everything was stable for months
:red_circle: Current Issue
Suddenly, I’m now seeing:
  • Lost connection to server message constantly
  • WebSocket connection errors (e.g., wss://<ngrok>.ngrok-free.app/rest/push?... fails)
  • PATCH requests to update workflows or triggers fail with 401s or timeouts
  • Even accessing via public IP (http://<EC2-IP>:5678) shows same issue
  • I can still log in and create workflows, but cannot deactivate or test them due to these failures
My Thoughts So Far
  • Could ngrok’s WebSocket support have changed recently on the free tier?
  • Could the Docker container be running with stale or invalid environment variables?
  • Is this a timeout/session/auth issue internally with n8n when it can’t fully sync via WebSocket?
I would appreciate any advice or even workarounds to make my n8n instance usable again without fully restarting or losing data.
