services:
n8n:
image: docker.n8n.io/n8nio/n8n:latest
restart: always
ports:
- "127.0.0.1:5678:5678"
environment:
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- N8N_RUNNERS_ENABLED=true
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- TZ=${GENERIC_TIMEZONE}
- N8N_EDITOR_BASE_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- N8N_TRUSTED_PROXIES=loopback,linklocal,uniquelocal,172.16.0.0/12
- DB_SQLITE_POOL_SIZE=1
- N8N_BLOCK_ENV_ACCESS_IN_NODE=false
volumes:
- n8n_data:/home/node/.n8n
- ./local-files:/files
volumes:
n8n_data:
<VirtualHost *:80>
ServerName n8n.<mydomain>.com
RewriteEngine On
RewriteRule ^/(.*)$ https://n8n.<mydomain>.com/$1 [R=301,L]
Alias /favicon.ico /var/www/html/n8n.ico
<Location "/n8n.ico">
Require all granted
</Location>
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/n8n.<mydomain>.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/n8n.<mydomain>.com/privkey.pem
ProxyPreserveHost On
RequestHeader set X-Forwarded-Proto "https"
RequestHeader set X-Forwarded-For "%{REMOTE_ADDR}s"
ProxyTimeout 600
ProxyPass "/socket.io/" "ws://127.0.0.1:5678/socket.io/"
ProxyPassReverse "/socket.io/" "ws://127.0.0.1:5678/socket.io/"
Header set Cache-Control "no-transform"
ProxyPass / http://127.0.0.1:5678/ retry=0 keepalive=On timeout=600
ProxyPassReverse / http://127.0.0.1:5678/
ErrorLog ${APACHE_LOG_DIR}/n8n_error.log
CustomLog ${APACHE_LOG_DIR}/n8n_access.log combined
</VirtualHost>
(obviously I only replaced my domain here, it is correct on my server)
“Connection lost” appears at the top of my workflows. I am unable to use certain tools such as Discord webhook integration. Attached is my docker compose file and apache config.
“Connection lost”
- n8n version: 1.111.0
- Database (default: SQLite): SQLite
- Operating system: Ubuntu
- Using cloudflare/apache
