Glorious not yet. For short of time it is gone and come back. I use n8n through Hostinger VPS. I tried to solve it through Hostinger .yaml content. It didn’t work at all. Some of my friends live same problem. I think It occured after an update in n8n or Hostinger.
Hi there @Servet , there’s a couple things on why this could happen,
something like, your workflow might make your vps crashes or make it very heavy that it crashes the server and make you see the lost connection, i sometimes experience tht, because im also on hostinger vps
or just bad network in general
but usually it is not something permanent, you can try to install the latest stable version of n8n, since it is the safest version that you can use for n8n
Hi @fahmiiireza, thanks. My n8n is latest vesion of 1.112.5. Not solved yet. I m still working on VPS firewall and any reverse proxy rules to ensure that WebSocket connections are allowed and not being blocked or timed out.
