Connection Lost when AI is executed
I tried using the trial version of n8n, but I couldn’t retrieve the final result because n would be “connection lost” every time the Summarizer Agent node was executed.
  • n8n version: 1.101.1
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Cloud
Hi there, hope all is well.
Can you screenshot your problem here? Or maybe describe the error message that coming from Summarizer Agent node.
“Connection lost” when running summarizer agent
pake server apa bang?
your message was hidden, can u just send it again?:slight_smile:
cloud or trial n8n
I think you should ask to n8n teams for your case, I can’t help:)
“Thanks, appreciate for your reply. Do u know how can I reach out them ?”
