Hey. Hope you all are doing fine.
I have deployed n8n to a server via docker (using Dockerfile in n8n-custom directory). The problem is there is a connection lost error in the header:
But workflows can be loaded and saved successfully, But they can’t be activated.
Also webhook URL is localhost:5678.
Where should I make some changes to fix this?
Thank for the help in advance.
