Hello everyone,
I’m building a public chatbot using n8n (LangChain AI Agent + Chat Trigger), and I’m running into an issue when trying to make the chatbot publicly accessible.
My setup
Chat Trigger node (public enabled)
AI Agent node connected to:
OpenAI Chat Model (GPT-5-mini)
Pinecone Vector Store (RAG setup)
OpenAI Embeddings (1536 dimensions)
Chat Response node enabled
Response mode configured for response nodes
Problem
When I send a message to the public chatbot URL, I get:
“Connection rejected”
Sometimes: 500 Internal Server Error
In executions, the workflow appears stuck at “waiting” or never completes the response node
What I observed
The workflow does trigger correctly
The AI Agent starts execution
But the final response is never returned to the chat node
Execution sometimes stays “running” without finishing
What I already checked
Credentials are correctly set (OpenAI + Pinecone)
Vector dimension is correct (1536)
No local nodes are used (fully cloud setup)
Response mode is set to Using Response Nodes
AI Agent is connected properly to Chat Trigger and Chat Response node
Question
Has anyone experienced this “Connection rejected” issue with public chat triggers + AI Agent?
Is there a known issue with:
responseNodes mode
or Chat Response node not returning output properly
or Pinecone tool blocking execution?
Any guidance would be really appreciated ![]()
