I used to be able to connect my n8n cloud instance to LinkedIn via the LinkedIn node and post text. At one point, I had to delete the credentials. Now, I am unable to reconnect. Any attempt fails. (Hint: I also updated the app to 1.93.0)
What I tried:
- Deleted browser data
- Retried on Chrome
– Retried on Safari, Incognito & Non-Incognito
- Deleted old n8n-connections in LinkedIn (Available Services, “Zulässige Serviceleistungen”)
- Created a new (dummy Account) on LinkedIn
- Tried Legacy setting to ON
Person Name or ID is marked with the error “Issues: There was a problem loading the parameter options from server: “Unable to sign without access token””
After creating a new Account (Toggles: “Standard”, “Organization Support”: OFF, “Legacy”: Off) I get a popup with an n8n-error-image which switches to an error text:
Error: Insufficient parameters for OAuth2 callback.
More details
Received following query parameters: {"error":"unauthorized_scope_error","error_description":"Scope "openid" is not authorized for your application","state":"eyJ0b2[...]"}
Failed to connect. The window can be closed now.
The green banner indicating a successful connection, doesn’t appear.
How can I (re-)connect my n8n cloud instance to LinkedIn?
Thx for your help, community!
n8n version: [email protected]
Database (default: SQLite): default
n8n EXECUTIONS_PROCESS setting (default: own, main): ?
Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
Operating system: MacOS 15.4.1
